  • SN95 4.6L Mustang Tech
Cat-back Install: Need Help
  • Thread starter Thread starter BigWind330
  • Start date Start date Apr 4, 2004
BigWind330
71
St. Louis, MO
Apr 4, 2004
  • Apr 4, 2004
Whats the best way to remove the stock cat-back hangers? should the cut over the axle be made first to allow removal? did you just knock the rubber isolators off with a hammer?
C
CottonBurnerz
Banned
May 10, 2003
1,554
Drink and Drive = Teh Lose
Apr 4, 2004
  • Apr 4, 2004
I just wrestle with the rod thing out from the rubber.. pretty PITA.. but you will get it eventually..
that's how i did it.. good luck man
oogtdude
Banned
Jun 9, 2002
1,626
  • Apr 4, 2004
drop the hangers much easier!
C
CottonBurnerz
Banned
May 10, 2003
1,554
Apr 4, 2004
  • Apr 4, 2004
what kind of cat-back are you installing? any other problem so far?
BigWind330
71
St. Louis, MO
Apr 4, 2004
  • Apr 4, 2004
should i make the cut over the axle before removing the hangers?
BigWind330
71
St. Louis, MO
Apr 4, 2004
  • Apr 4, 2004
What do you mean "drop the hangers"?
R
Roger_4.6_96
1,209
Reno,NV
Apr 4, 2004
  • Apr 4, 2004
you can unbolt them
oogtdude
Banned
Jun 9, 2002
1,626
  • Apr 4, 2004
Roger_4.6_96 said:
you can unbolt them
whoa is that bubblegum in your avater?
BigWind330
71
St. Louis, MO
Apr 4, 2004
  • Apr 4, 2004
Oh, yeah that would sure help a lot! Thanks man.
G
GinoGT
1,862
Apr 4, 2004
#10
  • Apr 4, 2004
  • #10
Unbolt all the hangers, cut the stock catback in front of the axle as high as possible.
oogtdude
Banned
Jun 9, 2002
1,626
#11
  • Apr 4, 2004
  • #11
yea cut at the curve thats what i did.....unbolt hangers to drop exhuast vs wrestle with rubber thingies
G
GinoGT
1,862
Apr 4, 2004
#12
  • Apr 4, 2004
  • #12
Oh yeah, when trying to remove/install the rubber muffler hangers:
Like I said, unbolt them so you can transfer the rubber hangers away from the car, where you have room to work. Use some Dawn dish soap or the equivalent to help you slide them on and off. DO NOT USE WD-40! I've heard WD-40 can break down rubber or something.
C
Need MIL Eliminators?
  • crazyone64
  • May 18, 2026
SN95 4.6L Mustang Tech May 21, 2026
GOvert
G
R
Interior and Upholstery Interior roof adhesive removal HELP
  • Riley Barth
  • Jun 22, 2026
Fox 5.0 Mustang Tech Jun 23, 2026
Riley Barth
R
Sound deadener install
  • limp
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 17, 2026
limp
L
Is catback worth it over axle backs?
  • Lorencarson
  • May 15, 2025
2005 - 2014 S-197 Mustang -General/Talk- May 15, 2025
89ripper
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
