  • SN95 4.6L Mustang Tech
Catback problems
  • Thread starter Thread starter rllndg17
  • Start date Start date Oct 4, 2006
R
rllndg17
129
Oct 4, 2006
  • Oct 4, 2006
I spent most of the afternoon yesterday cutting off the old cat back and installing a new mac cat back. Everything went well except I'm scraping in the rear end when it hits a bump/depression in the road. It seems like it's scraping near the rear axle on a metal bar that moves up and down (Don't know what the right word for it is, it's closer to the middle of the car, comes off the frame and hooks onto the rear axle). I messed around for a long time trying to get it to not scrape but I must be doing something wrong. I reused the rubber bushing from the old exhaust hangars and followed the instructions. Anybody have this problem or know a trick to fixing it?
Gabe
bakos24
I find there is nothing better than a tasty wiener
87
134
NE, OH
Oct 4, 2006
  • Oct 4, 2006
I had that probelm with my SLP. Mine was the part of the exhaust that goes over the axle. All I did was loosen up the clamps and adjust the angle of the pipes and tighten them back up again. That did the job for me.
You should be able to move the angle of them so they dont hit. Hope that helps.
R
rllndg17
129
Oct 4, 2006
  • Oct 4, 2006
Yeah that's exactly the problem I have...I guess I'm gona have to get back under there and try that.
stangman
2,690
10
69
in a 3 bed, 2 bath
Oct 4, 2006
  • Oct 4, 2006
if you have some ramps to back the car up on that will help you alot. reason being is the suspension will be compressed & you can see exactly how close it is when it's on the ground & then go from there
R
rllndg17
129
Oct 4, 2006
  • Oct 4, 2006
Yeah that's what I just did 20 mins ago w/ 2 people pushing the car down but I couldn't see anything...I'm gona get in there when the exhaust cools down and re-do it all
M
Mel96GT
255
San Diego
Oct 4, 2006
  • Oct 4, 2006
Those MAC cat-backs are not the best fitting esp. if you lower it. Mine was fine until I lowered it and went over bumps or cornered. I got some adjustment with the flanges.
D
Dragstr05
643
Stafford VA
Oct 4, 2006
  • Oct 4, 2006
Most people do have problems fitting catbacks through there, I know I did myself. Ultimately, I ended up sacraficing the appearance for fit. The tips are slightly cocked so that everything underneath the car clears. Its just way too tight under there.
H What 4.6
56
  • Oct 4, 2006
My MAC cat-back is really close to i ended up having to bend a flange that stuck off of my gas tank to get everything to line up without touching or banging... just play around with it and dont get frustrated because eventually you will get it right..
R
rllndg17
129
Oct 4, 2006
  • Oct 4, 2006
I finally got it to fit right w/ my roommate helping me hold the mufflers in place. It's still real close but I drove around and hit some dips w/o hearing any bad scrapes. I spent a while trying to line up the tips too that was a pita and they're still not perfect...the pipe is rubbing on the gas tank, I don't think that should be a problem?
thanks for the replies
R
rllndg17
129
Oct 4, 2006
#10
  • Oct 4, 2006
  • #10
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
SN95 Abs Sensor Replacement Trick
  • Farmstad
  • May 22, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2024
Farmstad
H
New kid on the block
  • HydraX
  • Mar 22, 2025
  • The Welcome Wagon
The Welcome Wagon Mar 22, 2025
HydraX
H
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
