  • SN95 4.6L Mustang Tech
catback removal ?
  • Thread starter Thread starter the98stang
  • Start date Start date Mar 14, 2006
the98stang
2,408
Clovis, CA
Mar 14, 2006
  • Mar 14, 2006
Hey guys I got the H pipe off after one hour lol..
Now it's time for the catback. Can the pipes go around the axles or will the mufflers HAVE to be cut? I borrowed a recip. saw from a friend but I think the damn blades are made for wood because they won't cut through the muff metal! I can get new blades tomorrow or try to get the pipes around the axles tonight. Thanks!
Tanner
Stang|ess
seeking cyber partner(s)
Oct 18, 2003
941
Hawaii
Mar 14, 2006
  • Mar 14, 2006
You can remove the pipes without cutting by dropping the rear axle. If you have a hacksaw avail, it should do the job.
the98stang
2,408
Clovis, CA
Mar 14, 2006
  • Mar 14, 2006
what do you mean by dropping the rear axle? the jack stands are on the frame and the axle dropped down a good amount. Will the pipes clear it?
Kronos
101
the boondocks
Mar 14, 2006
  • Mar 14, 2006
i just now thought of this and i don't know if it will work but if you can lift the caar high enough it should be able to slide right out and under. Shouldn't it i could be wrong and i know you prbly don't have a lift but it may be a solution.
Mach1Run
333
Wylie, Texas
Mar 14, 2006
  • Mar 14, 2006
When I did the GT, I backed it up the ramps first. The n supported the side I was going to work on with a jack and then raised it enough to take all the weight of the shock and quad without having the wheel come off the ramp. Unbolted the quad and shock and raised that side until I could get the CB over the axle. then lowered the body until the bolt holes lined up and bolted it all back together. rinse repeat for other side.
L
Is catback worth it over axle backs?
  • Lorencarson
  • May 15, 2025
2005 - 2014 S-197 Mustang -General/Talk- May 15, 2025
89ripper
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
G
Quiet my 2015 GT on the cheap
  • gsrblack
  • Feb 12, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Apr 16, 2025
gkomo
Progress Thread 1989 LX 5.0 convertible - mild project
  • Scott_S
  • Aug 18, 2025
  • 5 6 7
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 15, 2026
DadLife0724
D
Exhaust Bbk mid pipe and flowmaster catback fitment issues?
  • dqureshi06
  • Jun 8, 2024
Fox 5.0 Mustang Tech Oct 15, 2024
dqureshi06
D
