myponyrocks said:
maybe you should post what you missed in case some one else has a case of the stupids
good call. for those that have bilsteins, they have an internal bumpstop... this is mentioned many times all over this site, on the bilstein instructions, as well as everuy place a strut is mentioned on MMs site... so i figured the bumpstop that came with the CC plates would not be used.... before you get to the part about the bumpstop it has a lil note saying just what i wrote... if you have bilsteins, you will NOT use the zipties or the bumpstops that come with the kit. Bilsteins have this taken care of as part of their shock... saves a step... but now i have thses black cones sitting on my desk i am trying to figure out what to do with...
side note... the install was very very easy. something to point out is that depending on your setup you might have to do 1 or two other things that are not mentioned in the instructions. I couldnt get my strut low enough to get the stock perch off the top... and since i did not have a compressor (and i'm kinda small build so not He-man) i was unable to compress the strut shaft to remove this. if you are in the same boat then when you have the strut tensioned released (meaning you have the suspension at full extension, but everything still connected, you have used a jack to take the weight off the strut) i unbolted the swaybar endlinks top nut and remove it and the bushing... this allows the LCA to be lowered farther.
my second instance is that the brake hose was too short and became the limiting factor on how low i could drop the strut. so i unbolted the caliper (the two small bolts on the farthest parts of the caliper 12mm i think) used a large C clamp to slightly compress the brake pistons and removed the cliper from the rotor/mounting. now you are supposed to use a wire to hang the caliper so its not putting tension on the brake line... however i didnt care as my lines are comming on monday (cobra calipers and pads are here now, just the hoses and rotors are in UPSs hands).
removing the caliper and the top nut to the swaybar endlink allowed my to get the strut into the wheel well so i can do whatever i needed without issues of clearance. so now that its done i am off to the alignment, with my last 2 cinnimon buns
and no, not enough to share...
Torinalth
