I've spent the last few hours reading through old posts about fan issues, but I haven't come across my exact situation yet. I installed the manual fan switch a while back via the instructions in the FAQ and it always worked fine.
My AC hadn't been working very well for a couple months so I usually ran with it off along with leaving the fan switch off. My compressor finally seized not too long ago and I decided to overhaul the AC system. After fixing the AC, my fan woes began.
After reading through old posts and doing my own troubleshooting, this is the issue I'm faced with. The fan will turn on at low speed automatically when warmed up. This leads me to believe the ECT is working properly. High speed however, does not work. Neither with the AC on or with my old fan switch. I've run 12v to both the low and high pins on the fan and they seem to work fine, so I don't think there is a problem with the motor. I'm starting to think the high speed relay inside the CCRM is the culprit.
Should I try swapping out the CCRM or just bypass it and wire up a couple relays with two switches? Would standard 30a bosch relays be enough to run this? If I connected a switch for the high speed would it damage the fan if the low speed was still being controlled by the CCRM?
