What a mistake in design. If you use the CDC gauge cluster and plan on installing a boost gauge you may have problems. I did! If your boost gauge has the fitting on the bottom of the gauge for the hose connection the fitting will hit your dash causing the cluster to not seat flush with the dash pad. Considering a new dash pad is not all that expensive to replace, I went ahead and put a hole in the dash so the hose fitting can be below the dash pad level. I plan on leaving the cluster on the car so no big deal. I used Autometer gauges and I don't know if other brands would have the same problem.
