  • 1994 - 1995 Specific Tech
CEL flashed on a few times
  • Thread starter Thread starter The Green GT
  • Start date Start date Nov 1, 2006
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
Nov 1, 2006
  • Nov 1, 2006
I was on my way from school and I noticed my CEL was on. It went off soon after and came back on after a few minutes, then went off again in under a minute. I was accellerating in 5th gear up a slope when it came on so that kight have something to do with it.
Here are the codes I got.
111 PASS
10
172 Heated oxygen sensor indicates lean condition, right side
What needs to be done?
And my codes for the fan relay circuit fault and fuel pump circuit fault are gone since I changed the CCRM.
m0l0
178
Nov 1, 2006
  • Nov 1, 2006
111 PASS
10
I will most likely means that your oxygen sensor is bad, i had the same code but on the left side after i got on a flooding , after that the oxygen sensor was making that code , replaced both and no probs since then, i will highly suggest to replace both at the same time , since you will like to have clean readings to the eec on both banks
Ohh and of couse disconnect battery while you are changing them!
The Green GT
1,269
Louisiana
Nov 1, 2006
  • Nov 1, 2006
Those things are pretty expensive to huh?
94-302-vert
1,947
NE CT
Nov 1, 2006
  • Nov 1, 2006
$55-$80 each if I remember correctly...
The Green GT
1,269
Louisiana
Nov 1, 2006
  • Nov 1, 2006
Thats not too bad.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Nov 1, 2006
  • Nov 1, 2006
How exactly did you get a 10? That doesn't make any sense. There are no zero's in the codes.
The Green GT
1,269
Louisiana
Nov 1, 2006
  • Nov 1, 2006
The 10 means nothing, just a divider between the codes.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Nov 2, 2006
  • Nov 2, 2006
Is this on a scantool of some sort? I am just curious.
The Green GT
1,269
Louisiana
Nov 2, 2006
  • Nov 2, 2006
Yea, Im not smart enough to do it with a test light. lol
And how do I know that its the o2 sensor and not an actual lean condition?
HISSIN50
34
129
Nov 2, 2006
#10
  • Nov 2, 2006
  • #10
I'd check the frequency and amplitude of switching on that particular O2 sensor. 5 minutes with a DMM can save 50 bucks.
Good luck.
The Green GT
1,269
Louisiana
Nov 2, 2006
#11
  • Nov 2, 2006
  • #11
Good luck.
And what would need to be done if they are fine?
HISSIN50
34
129
Nov 3, 2006
#12
  • Nov 3, 2006
  • #12
Since you're only getting a code for one side, there's a decent chance that it is the O2 itself, or the wiring to the O2.
Oddball questiono you run a narrowband O2 gauge? Some of them don't have high enough internal resistance and can almost freeze the O2 signal.
If you had two O2 codes, I'd think vac leak, MAF issue, etc. But with only one side, it's likely the O2. I can't stand buying new parts without testing first though.
Good luck Eric.
The Green GT
1,269
Louisiana
Nov 3, 2006
#13
  • Nov 3, 2006
  • #13
Ill test is sunday or so. And I dont have any type of A/F gauge.
G
Help! 93 Mustang 2.3L A4LD dies at idle
  • goofyfoot53
  • Nov 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 17, 2025
goofyfoot53
G
T
2002 V6 3.8L Help Me
  • TheIncompetentMechanic
  • Apr 4, 2026
  • 2 3
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
T
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
