CEL Issues
  • Thread starter Thread starter ColdAudio
  • Start date Start date Jan 14, 2006
C
ColdAudio
31
  • Jan 14, 2006
Hey guys, my car's been running alright lately but on ocassion a CEL will randomly come on and then it'll start to stutter/have no power like it's running either way too rich/lean. I figured it's alright I'll just pull the CEL and fix whatever... but I don't have a code puller. So I was told that I can pull codes by grounding the wire in the grey box in the EEC TEST box behind the driver's side strut tower while the key is in ON, the CEL should stay on long for the first digit and short bursts for the second digit, all I need to do is count the number of times it blinks. Problem is, when I ground out that wire all that happens is the CEL stays on steady and that's it. Am I doing anything wrong, or is there a very inexpensive code puller I can get for the diagnostic port? Thanks.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jan 14, 2006
  • Jan 14, 2006
bump
vristang
4,933
101
124
Seattle
Jan 14, 2006
  • Jan 14, 2006
jrichker has posted a link to cheap readers quite a few times.
do a search on his name and you will find it.
bill302
2,131
alabama,gadsden
Jan 14, 2006
  • Jan 14, 2006
you need a circuit light tester ar analog volt meter or a obd1 tester you can purchase from wal-mart for $30 or autozone will do it for free. you read codes with above listed devices at the plug not at the check engine light like on a chrysler. but below is a link on exactly how to do it . also i had similar problems a few weeks ago turned out to be oxygen sensors but i was throwing two codes i fixed one the other was linked to oxygen sensor system be sure to post codes retrieved and let these guys help you they will save you alot of money.
http://www.muscularmustangs.com/test1.php
bill302
2,131
alabama,gadsden
Jan 14, 2006
  • Jan 14, 2006
heres another link good info. here in link click on solving idle problems 1-5 these steps will also often fix the type of problem your having like setting tps and cleaning maf and good luck.
http://www.muscularmustangs.com/maintain.php
troyGT03
278
too close to memphis,tn
Jan 14, 2006
  • Jan 14, 2006
http://www.troublecodes.net/Ford/ shows how run codes and the code definitions.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 15, 2006
  • Jan 15, 2006
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
C
ColdAudio
31
  • Jan 15, 2006
thanks a ton for all of the replies, i think ill order that one with the lcd display simply out of laziness, but until then ill use the old school way of reading the codes... thanks again!!!
Engine Information that is Needed When You Post a "Car is not Running" or "Car is Running Poorly" Thread
  • AeroCoupe
  • Apr 28, 2025
2K
Fox 5.0 Mustang Tech May 4, 2025
Bullitt347
P
CEL light on and Can't pull KOER codes.
  • psfoxstang
  • May 7, 2024
Fox 5.0 Mustang Tech Jun 20, 2024
psfoxstang
P
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
  • dan50
  • Jul 18, 2026
dan50
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
