I have been getting code 41 & 91 at WOT since I installed a GT40 intake, BBK TB, and C&L inlet tube. The funny thing is the code only appears when the pedal is mashed all the way to the floor regardless of RPM. I was thinking this maybe a fuel pressure issue or delivery volume issue, but I doubt that it would be showing up at the lower RPMs. I am going to swap out the FP and reg anyways since they are probably originals so maybe that will help a bit. I am going to also try clocking the C&L mass air a few times and see if that helps. One last thing, I currently have platinum plugs in the car and will be swapping in some copper motorcrafts....I know, I know...don't run the platinums but I didn't know any better.
I was just checking to see if anyone else has dealt with an issue like this and may have some pointers. The Check engine light appears only when the pedal is all the way down....once you lift the light goes out. Seems to be regardless of RPM.
I probably do need to ensure my timing is set properly after the intake swap as I just marked the distributor when the timing mark was at 0 and re-stabbed after the intake install. Doesn't seem to ping, but I got a backfire through the intake once which is probably associated with a lean WOT condition.
Thanks for any tips.
