  • 1994 - 1995 Specific Tech
changed clutch now tranny problems
  • Thread starter Thread starter jtb19nh
  • Start date Start date Sep 22, 2006
jtb19nh
156
Sep 22, 2006
  • Sep 22, 2006
i just changed my clutch. flywheel, pilot bearing,rms,clutch fork,and tob.. when i took it for a test drive i couldent shift into 2nd or forth it just grinded 1st 3rd and 5th and reverse were fine... does it sound like bad synchronizers. everything was find b4 the clutch install...
fluffyrunnells
new hampshire
Sep 23, 2006
  • Sep 23, 2006
HISSIN50
34
129
Sep 23, 2006
  • Sep 23, 2006
Check the shift stops in your shifter.
Good luck.
jtb19nh
156
Sep 23, 2006
  • Sep 23, 2006
i already checked that... any other suggestions...
fluffyrunnells
new hampshire
Sep 24, 2006
  • Sep 24, 2006
True 5.0
237
Southeastern Wisconsin
Sep 24, 2006
  • Sep 24, 2006
Sounds like the clutch isn't being fully disengaged. pull up on your clutch pedal to ratchet the adjuster.
parchisi
519
New Mexico
Sep 24, 2006
  • Sep 24, 2006
try getting an adjustable clutch cable and/or a firewall adjuster. I agree with True 5.0 that it sounds like the clutch isn't fully disengaging.
jtb19nh
156
Sep 24, 2006
  • Sep 24, 2006
i have an adjustable cable and firewall adjuster. If the clutch wasn't being fully disengaged it wouldnt be just 2nd and 4th it would be all the gears... any other ideas???
True 5.0
237
Sep 24, 2006
  • Sep 24, 2006
Some things to try to help make a diagnosis:
1. Try double clutching. In days before synchros this was the meathod used to shift gears. This will rule in or out the synchros.
2. If the synchros seem OK, try to shift without using the clutch. I used to drive a truck and learned this technique. The cluch was only used for 1st and reverse. I've used this technique in my Mustang and i know it works. Start off in 1st and when you would normally shift, just take your foot off of the gas and at the same time gently pull the shifter to the 2nd gear position. Don't ram it into gear, just lightly pull back on the shifter. When the engine RPM's match the 2nd gear tranny RPM's, the shfter will pop into 2nd. Hit the gas and repeat for 3rd and 4th. If this works, your clutch is out of adjustment or AFU'd.
3. If neither one of these work, your shifter is out of adjustment or your tranny internals are probably messed up. ie bent forks
jtb19nh
156
Sep 25, 2006
#10
  • Sep 25, 2006
  • #10
"I believe 2nd and 4th are connected in linkage. Did you drop your transmission or tilt it back/forward or jar the transmission?? There is a linkage, that if it shifts forward, you won't be able to shift.
Very simple fix. You take off the top cover, and slide the linkage forward, I believe.
If this is the case, I'll try to find a picture for you...however, it does require taking out the transmission.
I had this happen to my TKO during shipping. Its the only thing I can think of if everything else is set properly"
Has anyone ever heard of this.... it would make sense but im not too sure that 2nd and 4th are connected...
94-302-vert
1,947
NE CT
Sep 26, 2006
#11
  • Sep 26, 2006
  • #11
Try adjusting teh FWA to the other end of the spectrum... It does sound like it is not fully disengaging aince now it grinds into 4 of the 6 total gears...
jtb19nh
156
Mar 11, 2007
#12
  • Mar 11, 2007
  • #12
I'm bringing this thread back... I still have not found the problem.. now the weather is getting nice and i want to fix it... It is only 2nd and 4th gear.... everything was fine b4 the clutch swap... Are 2nd and 4th connected some how... I am ready to just get a new tranny but i dont understand why they would just stop working after a clutch change???
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
