Changing Coolant fluid.. Little help finding the Drain plug
wms004
2,864
Los Angeles
Hey, I see the hoses there that I could release, but wondering if there is a drain plug somewhere. This is probably a stupid question so i'm gonna put on my flamesuit:), but I'm trying to do some stuff myself instead of keep paying other's for service
-wade
muzztangman said:
passenger side bottom of radiator, facing towards the fender, it's a white plug. don't overtighen it or it will break
Thanks, is there a radiator vent I should open while draining.. then close after refilling?
any important tips?
hey
Are you trying to do a full drain / flush / refill? Just draining via the plug will only drain about half the coolant in the system.
Check out www.bullitarchive.com in the general maintenance section for a do it yourself flush and fill. But the best way is at the shop or Ford dealer, I think they pump all the crap out at once.
Check out Redline Water Wetter, you add it to your coolant/distilled water mixture and it supposedly helps lower cylinder head temps more than by just antifreeze and water.
I've never done a full flush, just drained the rad. for my kb install. not sure on that one...
water wetter is a great product . It lowered my water temp by 10 degrees :)
Thanks guys.. I'll try some water wetter next time.. i've got the fluid drained so, gotta fill with what I have at the house now. I'm gonna run some hose water thru the system for a min or two to clear out the system, shut off the motor, wait for it to drain.. then fill with 50/50 mix..
thanks for the bullitt archive site.. it was informative.
