  • SN95 4.6L Mustang Tech
Changing diff fluid
  • Thread starter Thread starter BannonJr
  • Start date Start date Apr 23, 2007
BannonJr
215
St.Lazare Quebec
Apr 23, 2007
  • Apr 23, 2007
Hey guys...so I went out and bought some Royal Purple diff fluid...
75w90...as I was reading around in old posts I noticed alot of ppl using I different grade...did I get the wrong one? this is what I was told to use...
and also, I seen some ppl said to use RTV to use instead of a gasket...may sound dumb, but, whats RTV? and whats wrong with a gasket?
And, anything else I should know before changing the fluid?
Thanks!
Brute03
232
  • Apr 23, 2007
i've read somewhere that Ford switched over to 75w 140 in '01 but i'm not sure. RTV or gasket maker is a silicone sealer that's in a little tube, personally i think makes a better seal than just a gasket
BannonJr
215
St.Lazare Quebec
Apr 23, 2007
  • Apr 23, 2007
oh ya ok thanks
goshia
252
Mead, Colorado
Apr 23, 2007
  • Apr 23, 2007
Take a look at the following web page: http://www.weather-check.com/royal_purple.htm
RTV is the only way to go. RTV=Room Temperature Vulcanizer
DTNODYA
831
  • Apr 24, 2007
You use RTV to spread on the surface of the differential cover and the edge of the differential to make a good seal.
When you change the fluid, scrape all the funk off the cover/diff and then spray down the diff cover with brake parts cleaner/carb cleaner to clean it, wipe it down. Take a old t-shirt or another lint free rag and wipe down the inside of the differential. Before you apply the RTV, make sure that the mating surfaces are clean. Spread it over the bolt holes, put the cover back on, tighten bolts, done.
Not difficult at all. Just messy!! Get lots of paper towels and newspaper.
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
Drive Shaft/Rear Diff Issue on 2014 GT
  • DudeStang
  • Jun 16, 2025
  • 2010 - 2014 Specific Tech
2K
2010 - 2014 Specific Tech Jan 21, 2026
gkomo
