  • SN95 4.6L Mustang Tech
changing injectors
  • Thread starter Thread starter road rage
  • Start date Start date Nov 14, 2004
road rage
433
R.I.
Nov 14, 2004
  • Nov 14, 2004
Would changing the stock 19# nectors to 24# be a benefit and is there any thing else that would be needed to step up injectors?
Go HoTO!
602
Mountaintop, PA
Nov 14, 2004
  • Nov 14, 2004
When chaging injectors, you need to get the car tuned. Otherwise, the ECU will assume that you have 19 pounders and you will run very rich. There is NO benefit to doing this unless you have added more hp so that the stock injectors can't support the added power. The stock injectors can support about 350 hp I think at the flywheel....probably more.
tomustang
Psychotic Member
3,434
McLean Hospital
Nov 14, 2004
  • Nov 14, 2004
anything with over 300hp should have bigger injectors, it'll benefit the nitro
you have to recalibrate the mass air meter to the injector size
4.6 spitting o-rings out of 2 injectors
  • skidad
  • Sep 30, 2026
  • 2 3 4
2K
1996 - 2004 SN95 Mustang -General/Talk- Nov 4, 2026
skidad
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
Fuel rail help
  • stang9150
  • Mar 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 5, 2026
stang9150
