changing injectors
When chaging injectors, you need to get the car tuned. Otherwise, the ECU will assume that you have 19 pounders and you will run very rich. There is NO benefit to doing this unless you have added more hp so that the stock injectors can't support the added power. The stock injectors can support about 350 hp I think at the flywheel....probably more.
