changing rear side windows
palone18
i have an 86 coupe with the small rear side windows and the plastic pieces, someone told me i could upgrade it to the newer style coupe with the big rear side windows. how would i do this?
  • Sponsors(?)
ID89GT
1,659
18
49
Spokane Valley, WA
Pull the quarter interior panels off and you will see the nuts holding the windows on the backside, unbolt them all then take a knife and carefully cut the window sealant around the window untill its off, reverse for install
skunk21
1,203
Taxachusetts
pretty much like ID89GT stated. make sure you clean of all the old sealent good. get some 1/4" butyl tape for the reinstall. I have heard of some people using windshield uerthane type stuff but if ever need to get them off again it could be a real problem but it will work also. The tape works fine though. if you do use a caulk type material don't put on too thick or it will not compress down enough and over cranking on the window studs to get it flush could shatter the window.
palone18
the small window has like its own frame around it and where the plastic stuff is it is solid behind it?
skunk21
1,203
Taxachusetts
I'm not really sure what you are talking about..if its the car itself you are talking about then yes. here is a pic of my car w/o the glass in. the structure is pretty much the same '79-'93. the newer glass is well more glass and appears larger, the newer style has a tinted area and small opening.
ry%3D400
ry%3D400
palone18
i had the guy explain to me how to do it, i know what you guys are talking about now. thanks alot
Thread starter Similar threads Forum Replies Date
Blackened302 change-up: ditching side skirts and rear bumper 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 46
Cam Coppola Rear Gear Change 1994 - 1995 Specific Tech 5
M Drivetrain 8.8 rear end change from 2.3ltr NA car Fox 5.0 Mustang Tech 2
9 Brakes Anyone Ever Manually Change Their Brake Bias Before?(front Bias To Rear) SN95 V6 Mustang Tech 1
Mikes2011GT Rear End Change 2005 - 2014 S-197 Mustang -General/Talk- 7
D Gt Rear Bumper Change 1996 - 2004 SN95 Mustang -General/Talk- 3
from6to8 Alignment Needed When Changing Rear Arms Upper And Lower As Well........ 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 31
M 2014 Mustang Rear End Gear Change V6 Auto - Whine And Vibration 2005 - 2014 S-197 Mustang -General/Talk- 1
Richard Wright rear gear change Fox 5.0 Mustang Tech 1
Clair Smith Transmission/rear-end Fluid Change. 2010 - 2014 Specific Tech 5
1993whtstang suggestion on reduilding rear end, change axles? Fox 5.0 Mustang Tech 2
94GTLaserRC Some Questions for those who Changed Rear Gears 2010 - 2014 Specific Tech 2
R Rear diff fluid change SN95 4.6L Mustang Tech 5
mhjo Change rear gear ratio when converting to AOD Classic Mustang Specific Tech 8
russ1979 Help 8.8 rear diff., oil change Fox 5.0 Mustang Tech 3
Hickfied How To Change Rear Brakes? 99-04 SN95 4.6L Mustang Tech 3
T Rear Axle Change for GT Automatic ?? 2010 - 2014 Specific Tech 8
superstang01 will changing rear shocks afftect ride height? 1996 - 2004 SN95 Mustang -General/Talk- 1
S Changing Rear Brake Pads SN95 V6 Mustang Tech 4
Killa how to change rear blinker ? and clutch adjust SN95 4.6L Mustang Tech 2
sam woodson 01 Cobra Rear Gear change, Tools needed? SN95 4.6L Mustang Tech 4
6 How do you change the fluid in a 8" rear diff? Classic Mustang Specific Tech 10
M Changing rear diff fluid 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
5spd GT Quick question about rear brakes as I change rotors/pads. SN95 4.6L Mustang Tech 11
DarkoStoj changing rear axle bearings on a 9" Classic Mustang Specific Tech 3
L rear end change out SN95 V6 Mustang Tech 17
D Rear Brake Change problem -ASAP Fox 5.0 Mustang Tech 1
65fastbackresto Considering rear end change Classic Mustang Specific Tech 26
Mustang5L5 Changing rear diff fluid...no friction mod needed with Mobil 1?? SN95 4.6L Mustang Tech 16
Slapyo whats needed to change rear end seal? SN95 4.6L Mustang Tech 14
P Difficulty in changing rear-end gears? Fox 5.0 Mustang Tech 12
J How to change rear main seal in 90 5.0 Fox 5.0 Mustang Tech 2
urban96 changing rear end fluid SN95 4.6L Mustang Tech 4
H Exhaust note changed after being rear ended 2005 - 2009 Specific Tech 16
go-stang5.0 Has anyone changed the rear abs sensors? 1994 - 1995 Specific Tech 5
AmBo Another little change (Rear Emblem Overlay *pics*) 1996 - 2004 SN95 Mustang -General/Talk- 21
S Changed Rear End Diff fluid, now leaks? SN95 4.6L Mustang Tech 11
Az Pete '00 rear seat changing.. SN95 4.6L Mustang Tech 5
MI95Cobra changed mind about rear bumper... 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 11
3 Changing rear springs... Fox 5.0 Mustang Tech 4
K So how hard is it really, to change the rear end gear? SN95 4.6L Mustang Tech 4
squares98 Drag Racing Rear end oil changes SN95 4.6L Mustang Tech 1
oz Rear Main Seal - changing it w/ engine in car - Advice Please?!? Classic Mustang Specific Tech 11
steveb24 changing rear brake pads SN95 4.6L Mustang Tech 17
K 28 spline to 33 spline- what inside rear end needs changed Fox 5.0 Mustang Tech 3
W Have to change my oil pan gasket and Rear Main, what should I do? Fox 5.0 Mustang Tech 12
V Rear End oil change Fox 5.0 Mustang Tech 2
94GTMOOSE Changing rear brakes 1994 - 1995 Specific Tech 7
K Rear end gear swap changes emissions??? 2005 - 2009 Specific Tech 10
spdfrkaby ???Changing rear end for supercharger??? SN95 4.6L Mustang Tech 9
