Changing.........
  • Thread starter Thread starter gebasgt
  • Start date Start date Jan 5, 2007
G
gebasgt
95
  • Jan 5, 2007
my speedo gear. How easy is to change it out and how long should it take???
89streetbeast
365
horton,ks
Jan 5, 2007
  • Jan 5, 2007
speedo gear is pretty simple. take the bolt and clamp off that holds the cable into the tranny case. theres a clip that holds the gear on the cable , use a set of needlenose pliers or a flat-tip screwdriver, pull the clip, pull the gear and install the new gear w/clip and bolt cable back up to tranny case.
G
gebasgt
95
  • Jan 5, 2007
Wow, didn't know it was that simple. Thanks a lot.
JChalfan
551
Bellevue, WA
Jan 5, 2007
  • Jan 5, 2007
It'll probably take longer to get the car up on jack stands than swap the gear. Not really, but it's quite easy. Just follow 89streetbeast's instructions, shouldn't take more than 5 min once the car's up in the air, 10 max.
Jeff
Engine Standard or hi flow water pump?
  • AnthonyA1234
  • Sep 28, 2026
Fox 5.0 Mustang Tech Oct 9, 2026
2000xp8
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Exhaust Exhaust resonance
  • keel
  • Jul 24, 2026
Fox 5.0 Mustang Tech Aug 11, 2026
keel
D
Speedo and tach dead
  • Davinrobinson1
  • Jul 19, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jul 26, 2026
fasterthangas
F
