Charcoal canister question
  • Thread starter Thread starter 1hot87gt
  • Start date Start date Aug 25, 2024
First Prev 2 of 2
Mustang5L5
Mod Dude
Feb 18, 2001
43,346
18,081
224
Massachusetts
Oct 23, 2024
#21
  • Oct 23, 2024
  • #21
Yes. One bolt to the frame rail and then you lift it up out of a slot
1hot87gt
5 Year Member
Mar 17, 2017
445
338
93
New York
Oct 23, 2024
#22
  • Oct 23, 2024
  • #22
Thank you
Admin Dude
Jan 4, 1985
43,463
21,647
234
Box behind Walmart
Oct 23, 2024
#23
  • Oct 23, 2024
  • #23
Hmm... A chamber
of charcoal and
potpourri.
Scented canisters
for cars and coffee
Reactions: General karthief
1hot87gt
5 Year Member
Mar 17, 2017
445
338
93
New York
Aug 13, 2025
#24
  • Aug 13, 2025
  • #24
Can you believe it took me this long to FINALLY get to this project. First of all, screw that little bolt at the top that holds the canister in place. I dropped the whole bracket and canister out in one piece by removing the two bolts underneath the car. Much easier. But before I did that, I had to remove the two lines connected to the canister. The larger of the two with the elbow came off easily. The smaller one was a different story. I pulled and pulled and then pulled some more. Nothing. So I cut it as close to the tank as possible. Dropped the bracket and canister. Once out of the way I was able to access the valve. The electrical plug came right out, but both lines going into and out of the top of the valve were also stuck to the point they had to be cut. Once the new valve was installed and both hoses hooked back up, I installed the new tank onto the bracket, swapped over the dust caps, and reinstalled the whole thing. I didn't snug the bolts because I had a feeling that even though I cut just a little bit here and a little bit there to free all the old parts and pieces, that it was gonna be just enough to screw me and not be long enough now to reinstall. I was right. Factory gives you nothing extra, even back in 1987. Lol. Anyway, no biggie. Just gonna pick up a couple of inches of each sized hose and a couple of T fittings, and should be fine. Existing hoses are all in good shape so I'm not sweating it. While I was under there I drained the fluid in my Vortech V3, and put some new stuff in. It was due. Anyway, hope to have this wrapped up so I can take her out for a blast this weekend. Weather looks good. We shall see.
Reactions: Scrapla347, Mcmahst, General karthief and 1 other person
First Prev 2 of 2
R
Engine Evap and charcoal cannister leak
  • ryan1994stang
  • Mar 14, 2026
Fox 5.0 Mustang Tech Mar 18, 2026
Mcmahst
L
Canister inside passenger fender
  • Livelife791
  • Mar 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 11, 2025
Mustang5L5
D
Fuel 1985 GT Fuel Line Diagram
  • DienstXIV
  • Apr 17, 2025
2K
Fox 5.0 Mustang Tech Jul 12, 2025
DienstXIV
D
  • brandyn200
  • Jun 20, 2026
AeroCoupe
'04 V6 running rich excessively on both banks
  • 04DSGVert
  • Oct 26, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Oct 27, 2025
04DSGVert
