Charging issues....
  • Thread starter Thread starter flyinhigh90
  • Start date Start date Jan 21, 2013
flyinhigh90
107
San Bernardino
Jan 21, 2013
  • Jan 21, 2013
my alternator took a crap batt light came on it wasnt charging so i put another alternator was charging fine for 2 days then the voltage gauge drops to the second line from the bottom up and if i unplug the negative while car running the gauge goes to the middle like normal and if i put the negative back it drops anyone knows this .....
madspeed
Colonel Mustard
1,332
204
a van down by the river
Jan 21, 2013
  • Jan 21, 2013
hit up your local autozone or advanced auto. They will do a system test for free
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 22, 2013
  • Jan 22, 2013
Excellent advice - do it!
HISSIN50
34
129
Jan 22, 2013
  • Jan 22, 2013
flyinhigh90 said:
....... if i unplug the negative while car running the gauge goes to the middle like normal and if i put the negative back it drops anyone knows this .....
Please don't do this anymore. It can cause a very harmful voltage spike.
J
jka
5 Year Member
Jan 17, 2010
339
23
29
Jan 22, 2013
  • Jan 22, 2013
I had the same problem last year i got one from autozone .
J
jka
5 Year Member
Jan 17, 2010
339
23
29
Jan 22, 2013
  • Jan 22, 2013
I had the same problem last year i got one from autozone ..it did good for two days then the voltage regulator went bad. So i had the guy at autozone to test the replacement alternator before i went home and it was bad just like the one i got before. Well long story short i had to drive 5 mile to another autozone to get a alternator that tested good.
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Jan 22, 2013
  • Jan 22, 2013
do a voltage drop test. the stock gauges are not accurate. And do not disconnect any cables while the car is running. You can fry the computer. chances are you have a bad ground .
flyinhigh90
107
San Bernardino
Jan 22, 2013
  • Jan 22, 2013
i hooked up my voltmeter and its just weird how it charges good then it dosent ill check my grounds
JordanB21
804
27
29
Killeen, Texas
Jan 23, 2013
  • Jan 23, 2013
If you ever buy an alternator from autozone/advanceauto always keep the recipt. The one year replacement is a sweet deal.
I've gotten 3 new alternators so far for my 95'. All because I run them into the ground before the year is up
J
jka
5 Year Member
Jan 17, 2010
339
23
29
Jan 23, 2013
#10
  • Jan 23, 2013
  • #10
You got that right..everytime i start my car i'm looking at the volts on the gauge.
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
C
Stock 1993 charging issue at idle
  • Charlie1
  • Sep 21, 2025
Fox 5.0 Mustang Tech Sep 24, 2025
Mustang5L5
Electrical Alternator not charging after terminator 2 install.
  • Sfab79
  • Aug 24, 2025
  • 2 3
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
