CHARGING
  • Thread starter Thread starter BILL S
  • Start date Start date Jul 22, 2006
BILL S
18
NASVILLE, TN
Jul 22, 2006
  • Jul 22, 2006
i have a `93 vert, underdive pulleys,eletric fan an 140amp alt. at idle lights are dime an shows about 8 to 10 volts. help!
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Jul 22, 2006
  • Jul 22, 2006
sounds like the alt may be the issue..I'd pull it and get it tested, next look at the wiring to see if anything is fried or worn/broken. The alt should show 13-14 volts at idle with few or no accessories running to make me happy.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 22, 2006
  • Jul 22, 2006
What does it indicate at 1000 RPM? The stock gauge isn't the best, you should use a digital voltmeter to do the checking. If you are putting out 14 volts at 1000 RPM, the pulleys may be the problem, or your battery is weak.
HISSIN50
34
129
Jul 22, 2006
  • Jul 22, 2006
Agreed. FWIW, a car has trouble not stalling at the voltage values noted (if that was battery voltage).
8950HO
658
  • Jul 22, 2006
Try a smaller pulley on the alternator at least the size of a 2g pulley,since you have underdrive pulleys.
BILL S
18
NASVILLE, TN
Jul 22, 2006
  • Jul 22, 2006
battery is old, but starts the car fine. all lights are good at 1200rpm. going to try new battery an cables. thanks!
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 22, 2006
  • Jul 22, 2006
Five minutes spent with a digital voltmeter to test the alt output or have the auto parts test your charging system is a bettter use of your time & money. Don't throw parts at a problem in hope of fixing it. You'll just get poorer and more discouraged.
bill302
2,131
alabama,gadsden
Jul 22, 2006
  • Jul 22, 2006
experience and wisdom = lol.
BILL S
18
NASVILLE, TN
Jul 22, 2006
  • Jul 22, 2006
your right, i will check it out first.
G
2000 GT- Alternator not charging
  • grugug
  • Nov 10, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Nov 12, 2026
squeak93
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
C
Stock 1993 charging issue at idle
  • Charlie1
  • Sep 21, 2025
Fox 5.0 Mustang Tech Sep 24, 2025
Mustang5L5
A
Resolved Electrical Help Please
  • Alabama
  • Jan 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
AeroCoupe
J
1990 fox starts on starting fluid only
  • Jfox
  • May 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 15, 2026
AeroCoupe
