I'm looking for some quality full length sub frame connectors. I've been leaning twards MM. Anybody have any experience with these? How well do they work and how much does installation usually cost.
I just put a set on last weekend... best mod so far, besides 3.73's. Made a big differnce in the feel of the car. I have a Vert and they are bad for doing the twist in the corners... I can not tell you how much you need these if you have a vert.
The kit is top notch, I got the full length bare metal from MM. Figured that no use grinding off powdercoating to weld it in.
The fit was good, very little fabrication. Really didn't have to do any, but I am kinda anal about fit so I did some fab work on it. the rear drivers side did not line up perfect, but I used a 7/8" wrench and a floor jack to lock it in and tacked it.
As far as the cost of install, I have not a clue. I would guess if I was charging ppl for install I would ask somewhere in the 100-150 range.
