Check engine light and no self test...WTF?
  • Thread starter Thread starter southbronx
  • Start date Start date Oct 12, 2004
southbronx
27
Portsmouth, VA
Oct 12, 2004
  • Oct 12, 2004
Anyone come across a 5.0 that would not do any of the self tests (KOEO/KOER)? I got a check engine light and tried pulling the codes with no luck. I've traced the wires for any faults and have come up dry. Still runs though.
BlackFox5.0
3,514
Massachusetts
Oct 12, 2004
  • Oct 12, 2004
Are you sure you jumpered the plugs properly?
A
autoXr1
1,838
Michigan
Oct 13, 2004
  • Oct 13, 2004
Insufficient grounding? Try taking a piece of 12-16ga stranded wire...stick one end into the small gray connector where you plug in your scanner...connect the other end to a good chassis ground or negative battery post. You should be able to run the self-tests.
Apart from not being able to run self-tests with a scanner, insufficient grounding can create all sorts of little tuning issues due to electrical "noise" and excessive voltage drop.
http://www.stangtuning.com/showthread.php?t=1656
southbronx
27
Portsmouth, VA
Oct 13, 2004
  • Oct 13, 2004
Grounding did the trick
Thanks autoXr1. Your advice did the trick. I've had Mustangs for 14 years (this one for 10) and have done all of my own work: upgrades, electrical, diagnoses, etc... but this was a first. I guess going to an upgraded 4 gauge alternator cable so the 130 amp alternator can push the juice must have been too much for the chasis to handle. I went ahead and swapped out for a heavier gauge grounding cable and cleaned up all of the 4-5 grounding points in the car. Thanks again. Semper Fi.
jb89coupe
416
CT
Oct 13, 2004
  • Oct 13, 2004
Is the CEL on all the time?
southbronx
27
Portsmouth, VA
Oct 20, 2004
  • Oct 20, 2004
No. The CEL went off as soon as I cleaned up the grounding points around the car, specifically the one near the computer. I also swapped out the negative cable for a heavier gauge (4 ga) and cleaned up the contact on the block. I had a 130-amp alt for a while and u/g the main cable just recently.
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
A
Check Engine codes jumping around
  • azactor
  • Jan 9, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 24, 2026
DadLife0724
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
