check engine light comes on
loudexhaust
99
Ive got a 91 GT and when my rpms get up before i shift, the check engine light comes on. The car runs great but i noticed that one of the O2 sensors was pinched. Looked like the guy used a vise grip to put it in. Could this be the problem? BTW i hooked up a tester to the computer and it didn't find anything wrong.
Just in case your tester was bad, dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
If the CEL illuminated, there should have been a code. DId you get no codes, or a system pass?
Are there any other symptoms?
You can use a DMM to check O2 sensor switching.
Good luck.
