Check engine light flashes for a second
  • Thread starter Thread starter fox-gt
  • Start date Start date Dec 15, 2004
fox-gt
204
TN
Dec 15, 2004
  • Dec 15, 2004
The last three days it has been about 15 degrees in the morning when I leave for work. I let the car warm up, then take off. About 3 miles from my house in almost the exact same spot, my check engine light comes on for about 2 seconds then goes off, doesn't come on any more for the rest of the day. Engine is mostly stock.
Any thoughts or anything I can check.
OL' WHITEY
273
Weddington, NC
Dec 15, 2004
  • Dec 15, 2004
Wow! I just posted the same question five minutes ago...basically. Except mine has gotten much worse lately. I pulled my codes and posted them for the code gurus to take a look at. Keep an eye on my thread and I'll keep an eye on yours. Maybe we'll get some answers.
rsw007
469
Lexington,SC
Dec 15, 2004
  • Dec 15, 2004
mine used to do that i took off the egr valve cleaned it good with carb cleaner. no more problems.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 15, 2004
  • Dec 15, 2004
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.dalidesign.com/hbook/eectest.html for more descriptive help
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
fox-gt
204
TN
Dec 15, 2004
  • Dec 15, 2004
I was looking at this one, it looks pretty cool. Where / What does it hook into to test?
http://www.partsamerica.com/PartDetails.asp?MfrCode=EQU&MfrPartNumber=3145
5.0 Nostalgia
904
CT
Dec 15, 2004
  • Dec 15, 2004
I have had a few of my cars do that in the cold. It's probably emissions related. Or a sensor going bad. Pull the codes. It will probably be something like EGR or thermactor pump.
MustangMuscle86
24
North Ridgeville,Ohio
Dec 15, 2004
  • Dec 15, 2004
Have a scanner check your computer for codes.
OL' WHITEY
273
Weddington, NC
Dec 16, 2004
  • Dec 16, 2004
As I said earlier, mine did the same thing. I took you guy's advice and replaced the O2 sensors last night (they had 125,000 miles on them) and cleaned out the egr. No more blinky. Yeeeaaahhhhh! Thanks guys!
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
