  • SN95 4.6L Mustang Tech
check engine light flashes?
  • Thread starter Thread starter 4.6litrebeater
  • Start date Start date Dec 21, 2004
4.6litrebeater
113
San Diego, CA
Dec 21, 2004
  • Dec 21, 2004
i posted before about my car throwing a code for misfire on cylinder 1, got no responses. today the light starts flashing at me, im sure thats no good. so i park it at home, pull the codes, same thing misfire on cyl 1 and nothing else? what gives? i thought coil pack, swapped it with cyl 3 then 7, still get misfire on 1. pulled the plug, looks just fine. measured resistance on the fuel injector, within specs. so im kinda stuck on it now
schiccc
78
  • Dec 21, 2004
does the car feel like it is misfiring
Turbo92PGT
746
Auburn Washington
Dec 21, 2004
  • Dec 21, 2004
These cars are gay, end of story. If you fart in the seat the check engine light will come on. Mine came on last night after I got in a wreck. Says that bank 1 was running lean and was pending bank 2 running lean. The car has been taking a LONG time to start the past few days. Its been about 35-40* around here, but seriously its like it doesn't even wanna start. You crank it for about 5-10 seconds and it'll finally fire up. I'm wondering if the fuel pump is takin a ****.
As far as your car and the check engine light, I dont really know what to tell you. I was having "multiple cylinder misfire" codes a while ago. Changed all the plugs, cleaned the MAF, ran some fuel injector cleaner through it n ****. Seemed to help.
4.6litrebeater
113
San Diego, CA
Dec 21, 2004
  • Dec 21, 2004
it is definatly misfiring, can hear it and feel it. i tried this today, removed the plug and put it on the end of the coil, had my buddy start the car, i didnt see any spark. so i changed it with another coil, even though ive done that before, still no spark. what else is there to check, i tried another spark plug just to be sure, same result
BeelzebubSOB
193
Iowa
Dec 22, 2004
  • Dec 22, 2004
I guess the first thing I would ask is,when you tested for spark with a plug in the coil,did you ground the plug? A lot of todays electronics in vehicles can be damaged if not grounded when a plug wire etc is removed.Anyway if you didnt I would try it again while grounding plug,or buy a spark tester,is a very handy cheap tool.
If possible check the wiring to the coil for an open,if the previous test still showed no spark and the wiring to the coil is ok could be a driver in the ECM not firing for that cylinder.
If there is power/spark to that cylinder,I would say try a compression test on the bad cylinder.If compression test is ok,could possibly be a faulty injector.If noid lights are available they are a quick easy test to check wiring to injector.
Vacuum leaks?? I guess one thing I learned from working in the automotive field for over 10 years was to not overlook anything,no matter how trivial it may seem.
The flashing mil is an indication that damage to a component may occur unless problem is fixed,in your case the catalytic converter,if you still have a mostly stock exhaust.
I just want to say that by no means am I a Ford expert.I am not very familiar with their setup even though I have owned mine for about 3 years.Just wanted to say that so if I gave misinformation that you know I am not a Ford master mechanic and to avoid getting flamed for trying to help.I like to be able to try and diagnose my own problems with my own vehicles and finally got myself a Snap-on scanner a few months ago and purchased the updated cartridges with the latest software.Have been wanting to hook up to my car a check the system to see what info is available.
Anyway,good luck and I hope you get your mis-fire figured out...
  • Gulftown980x
  • Jul 29, 2026
squeak93
A
Check Engine codes jumping around
  • azactor
  • Jan 9, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 24, 2026
DadLife0724
New misfire after replacing valve seals/springs.
  • SpeedofDarkness
  • Aug 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 24, 2025
SpeedofDarkness
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
