check engine light flashes?
i posted before about my car throwing a code for misfire on cylinder 1, got no responses. today the light starts flashing at me, im sure thats no good. so i park it at home, pull the codes, same thing misfire on cyl 1 and nothing else? what gives? i thought coil pack, swapped it with cyl 3 then 7, still get misfire on 1. pulled the plug, looks just fine. measured resistance on the fuel injector, within specs. so im kinda stuck on it now
These cars are gay, end of story. If you fart in the seat the check engine light will come on. Mine came on last night after I got in a wreck. Says that bank 1 was running lean and was pending bank 2 running lean. The car has been taking a LONG time to start the past few days. Its been about 35-40* around here, but seriously its like it doesn't even wanna start. You crank it for about 5-10 seconds and it'll finally fire up. I'm wondering if the fuel pump is takin a ****.
As far as your car and the check engine light, I dont really know what to tell you. I was having "multiple cylinder misfire" codes a while ago. Changed all the plugs, cleaned the MAF, ran some fuel injector cleaner through it n ****. Seemed to help.
it is definatly misfiring, can hear it and feel it. i tried this today, removed the plug and put it on the end of the coil, had my buddy start the car, i didnt see any spark. so i changed it with another coil, even though ive done that before, still no spark. what else is there to check, i tried another spark plug just to be sure, same result
I guess the first thing I would ask is,when you tested for spark with a plug in the coil,did you ground the plug? A lot of todays electronics in vehicles can be damaged if not grounded when a plug wire etc is removed.Anyway if you didnt I would try it again while grounding plug,or buy a spark tester,is a very handy cheap tool.
If possible check the wiring to the coil for an open,if the previous test still showed no spark and the wiring to the coil is ok could be a driver in the ECM not firing for that cylinder.
If there is power/spark to that cylinder,I would say try a compression test on the bad cylinder.If compression test is ok,could possibly be a faulty injector.If noid lights are available they are a quick easy test to check wiring to injector.
Vacuum leaks?? I guess one thing I learned from working in the automotive field for over 10 years was to not overlook anything,no matter how trivial it may seem.
The flashing mil is an indication that damage to a component may occur unless problem is fixed,in your case the catalytic converter,if you still have a mostly stock exhaust.
I just want to say that by no means am I a Ford expert.I am not very familiar with their setup even though I have owned mine for about 3 years.Just wanted to say that so if I gave misinformation that you know I am not a Ford master mechanic and to avoid getting flamed for trying to help.I like to be able to try and diagnose my own problems with my own vehicles and finally got myself a Snap-on scanner a few months ago and purchased the updated cartridges with the latest software.Have been wanting to hook up to my car a check the system to see what info is available.
Anyway,good luck and I hope you get your mis-fire figured out... :nice:
