check engine light help
SMOKEDYA
Jul 13, 2003
3,637
Tucson AZ
Last night leaveing the womans house i pitched the stang sideways a bit. Now the c/l is comming on and flashing not flashing fast but slowly. Then it stops and starts again? I have a 93 5.0 is this telling me something or could it be a loose connector on a sencer that might be causeing the c/l light to do this? It's flashing almost like its sending a code like other vehicale makes do? but i thought or stock ecm's wasent capible of doing this?The car dosent run any diffrent, any ideas what connector i should look for first? peace
john:p
It flashes because the problem is intermittent – it works OK for a while and then doesn’t work.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
attachment.php
attachment.php
Do not jumper anything to the single dark brown connector. It is the power for the under the hood light. It is in another bundle of wires near the windshield wiper.
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see EQUUS DIGITAL FORD CODE READER (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
