Check Engine Light... sound famliar?
BJBethel
317
Dayton, Ohio
Here's a question for you guys.
About a month ago, my check engine light started coming on. Basically, if I'm going down the road and just cruising, it never comes on, but if I give it a little bit of gas, it willl come on for a few seconds them come off. My dad things its the MAC air intake I installed, but I had it on there for several months and the CEI never came on. My thinking is its a sensor that needs cleaned or replaced. Anyone have any ideas where I should start?
It's probably not your upgrade. Mine's completely stock and does exactly the same thing. If I give it more gas, it goes away.
I've been ignoring it for years and never had any problems. My emissions pass perfectly.
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.dalidesign.com/hbook/eectest.html for more descriptive help
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 88 or earlier stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 88's except possibly the Cali Mass Air cars.
if you are pulling codes for your '91 Autozone probably can't help.the Autozone here in Raynham Mass. can only pull codes on newer cars like your '95 thats why i bought my own scanner for my '90 7up vert. for $35. good investment.
