checking piston to valve clearance
you cant use clay without takeing the heads off
there is one way to do it but not really feasable with the engine in car, easier to pull the heads but you can
use compressed air to pressureise the cylinder, replace valve spring with a light spring, use a dial indicator on the valve and rotate crankshaft slightly push rocker down see howe far dial indicator moved, slightly move crank cheack again lol ;D you'll be there awhile =O
normally you use this method with engine out and after you degree the cam, piston to valve clearance will be closest at +30 to -30 degrees from tdc, but without degreeing the cam, you'l be there awhile
