chin spoiler instalition tips...
hairdryer or let it sit out for an hour. try to have at least 1, maybe even 2 friends help you. two people hold it in place while the other marks/or drills the holes. it takes some patience to get it right, because the sides and front dont want to line up perfectly. just did mine saturday. you'll love it.
Make sure the spoiler is flush with the bottom of the bumper...dont try to pull it in so its flush with the front fenders or it will look gay, if you set it in place correctly you will have a half inch space between the front of fender and the beginning of the spoiler...at least I did.
+1...Very gay
+2...Did mind on sunday...Just about 1/2 inch
I did it by myself. Taped it on with masking tape and moved it till it was right, then drilled the holes. Also used some ramps so I could get under the nose easier. Took about 20 minutes to get it aligned then pinned on.
What's so bad about it not lining up with the front? I'd rather have it be a bit under the front fascia than not lining up with the wells...looks dumb as hell gapped from the wells IMO. To each his own though...
Give Me TP said:
These "experts" who say offset them from the wheel wells have no concept of how the factory installed them on the Mach 1. It's a good bet that any poster who uses the word "gay" is unknowingly admitting he knows nothing about what he just wrote.
Yes, the factory ones are aligned on the wheel wells not the front bumper
Start I started my at one end and placed the first screw in making sure that the oval hole at the end on the chin was flush against the plastic screw so that it could not move forward during the installation. I then did the other side making sure the chin is flush with the bumber ending. Then I moved to the center holes and then pulled the chin flush all the way around the bumper. Then Chin should come in a large box 2 feet by 5 feet almost and there should be no unwanted bends in the chin itself. If you got a chin that is packaged in a small box rolled up, don't use it you will not be happy, go to Ford and get the correct part Part # 3R3Z*17626*AAA
i got mine folded in 3 and it looks just fine. just let it sit out over night or use a hairdryer. had no problems with the install. we actually got it damn near flush the whole way around.
That's what's wrong. Correct placement will have the chin spoiler with little or no space at the front of the wheel well and about 1/16" between the bottom of the bumper and the front of the spoiler. If you would have left the word "correctly' out of your post it would of been fine, still wrong, but fine. I have the actual item, so argue all you want, you'll still be wrong.
End of lesson, class dismissed.
Give up on the gay ****, queerbait, you're still a douchebag, and still wrong
