yea that would work too, but my problem is that people who sell original cobras want 500 bucks for them, when i could spend a little more and get a trick flow and edelbrock.
I would not buy the China intakes. "one has less imperfections than the other"? Why not just pay a little more and get one that does not have any imperfections? Have you ever set one on an engine and looked at the serious port mismatch that they have. It may look good on its own off of the engine, but man from what I have seen, you will leave a lot of H.P. on the table if you run one. This is still one area that you get what you pay for IMHO. It is one thing to "save" money and another to waste it on cheap junk. There is a reason it is cheap, there is no R&D in those intakes at all. Just a "copy", maybe a good looking copy, but not a good working copy.![]()
Bullitt347 said:Point taken, BUT. If your time is worth anything then you really did not save any money buying the cheap intake, compared to buying the original and just bolting it on. If we both built identical engines, and you use the china intake out of the box, no "fixing" the damn thing, and I used an original out of the box, I will out H.P you EVERY TIME! If you want to port the thing, and I get to spend the same amount of time porting the original, I still will out H.P you every time. So it comes down to if you value your time and effort. I would rather work smart than waste time fixing a bad casting, but that is just me. If you have time to kill and nothing better to do, and your bored, then maybe the china syndrome is the way to go. Nothing personal, just my preference for what it is worth.![]()
I'm not trying to start a pi*sing match, but do you have any evidence to prove anything you said regarding making more HP with the original casting, versus the one made in China? And why would you make more power with the same amount of time in porting? If you ported both identically, you'd end up with the same variation you'd see from two original castings, unless of course you were to cut the upper plenum open and port it, to ensure exacting tolerances were met.
Given equal time to "port" instead of just clean up would yeild two identicle intakes.![]()
so where do I get a budget Cobra intake?
Allen
