chip where valve stud should go!! HELP
jggianna
10
Have a 66 Ford with a 302 and 351 heads...heads are new and engine newly rebuilt. Some background: have a smoking problem on the passenger side, (think a ring is stuck) 2 plugs were fouled...we replaced along with new wires (clearance issue). While running noticied some metal "particles" falling...next thing you know...there is a chip on the head where the valve stud should go...there are two chips...and the studs will no longer screw the valve cover on. I have never seen this before and don't know what the heck to do!!!
the stud is still threaded, and are able to put the valve cover back on, but I'm sure it will leak oil. If this is chipping...why? and does this mean this head will chip/crack some more.
