clearence issues
  • Thread starter Thread starter shttygtstang
  • Start date Start date Jul 1, 2004
shttygtstang
978
  • Jul 1, 2004
i have stock heads.i bought a f303 cam will i have any clearence issues with that cam and stock heads .also i have a head gasket thats 65 thousandths over on the car im doing a big install on a buch of parts in a couple days .can some tell me with no dought yes or no ow ya stock pistons and new valve springs
stangandy
23
  • Jul 2, 2004
you should be fine, I wouldnt worry about clearance issues unless you were using the x303 cam which lift is 542/542
shttygtstang
978
  • Jul 2, 2004
are you shure andy oh thank you for a quick reply do you think the valves will hit the head
saleenx029
117
Cincinnati, Ohio
Jul 2, 2004
  • Jul 2, 2004
The F-303 cam and the X-303 cam is designed to work in a stock head/ piston set-up. The Z-303 is the one you gotta worry about.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Jul 2, 2004
  • Jul 2, 2004
Lift has nothing to do with p to v clearance; you should always measure. There's no way around it. Even if it fits in someone else's motor with similar parts, each combo is unique. You gotta measure if you want to know for sure if you have enough clearance. Anything else is just guessing and hoping for the best.
_jb_
808
Michigan, Berrien County
Jul 2, 2004
  • Jul 2, 2004
How much power do you think the cam will give?
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Jul 3, 2004
  • Jul 3, 2004
I think that cam and stock heads are a mismatch - it's designed to work with better flowing heads, intake, exhaust, gears, etc. It's also way too much for the stock valve springs - they'll float early. It might make a bit more power if it'll rev high enough before valve float sets in; down low it'll be much softer than the stock cam. My guess is that it will actually lose average power. I wouldn't do it to mine -- but it ain't mine.
Clearance
  • 1993mustang50
  • Apr 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 4, 2026
2000xp8
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
Crank no start on a turbo and cammed pushrod 5.0
  • 1630stri
  • Sep 2, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
My next project , a 428 build!
  • horse sence
  • Jul 29, 2026
  • 9 10 11
4K
Classic Mustang Specific Tech Today at 6:48 AM
GOvert
G
