cleveland heads
  • Thread starter Thread starter scpu
  • Start date Start date Aug 20, 2008
scpu
  • Aug 20, 2008
I have four sets of 351c heads all 2v and was going to rebuild the two best ones. So can I do this,...take one good head from one block and another from a different block and combined them on one engine.Will this work?
one set is from a 71' and the other is a from a 70' block
dodgestang
1,360
Cecil County, MD
Aug 20, 2008
  • Aug 20, 2008
As long the are they are both 2v and the combustion chambers are the same size.
D
D.Hearne
11,730
south louisiana
Aug 20, 2008
  • Aug 20, 2008
Yea, you can, both should be the same castings. Have any been milled in the past? Or do you know? If you suspect they have, then have them cc'd to check chamber volumes.
Hack
1,945
Minneapolis
Aug 20, 2008
  • Aug 20, 2008
There are half moon shaped indents around the perimeter of the block mounting surface of the heads. Those indents provide a good indication of whether a set of heads has been milled. Compare the depth of the indents on the various heads to make sure that they haven't been milled.
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
P
Engine Mysterious coolant leak at back of engine
  • palerider94
  • Jan 18, 2026
Fox 5.0 Mustang Tech Jan 19, 2026
AeroCoupe
L
New here from Maine
  • lobster
  • Mar 2, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 5, 2026
lobster
L
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
