  • 1994 - 1995 Specific Tech
Clock isn't working.
  • Thread starter Thread starter will_95gt
  • Start date Start date Mar 25, 2006
will_95gt
298
Austin, TX
Mar 25, 2006
  • Mar 25, 2006
Sooo, anybody know what steps i should take to try and troubleshoot this. It hasn't worked for a long time now. Hopefully its just a power connection problem. Would i have to take the entire dash apart to get to it or what?
thanks,
will
MysteryMachine
1,835
Parkesburg, PA
Mar 26, 2006
  • Mar 26, 2006
is that all that doesn't work? Theres a 15 amp fuse in the fuse panel under the dash spot number 6 on the diagram. Check that first. Mine was blowing that fuse as soon as I'd turn the key. From there good luck as you can see its not a simple fuse that only controls 1 thing. Mine turned out being the keyless entry box in the trunk
SeventyMach1
Keep it lubed .... keep it straight .... and keep
Mar 30, 2005
1,940
North Carolina
Mar 26, 2006
  • Mar 26, 2006
Remove clock .... install clock pod gauges.
STM1965
185
Ontario
Mar 26, 2006
  • Mar 26, 2006
That one runs a lot of items, radio, power locks, keyless entry, the hood lamp
Mine turned out to be a short at the hood lamp! PITA! Good luck!
donjohn
1,757
Irvine - Southern California
Mar 26, 2006
  • Mar 26, 2006
the clock can be removed by pushing up and towards the windshield on the front top of it (if nobody already told you)
JOEGTS
153
Port Saint Lucie, FL
Mar 26, 2006
  • Mar 26, 2006
Just buy a new clock. Mine worked fine except when you turned the lights on. I tested it with a friends car and it was the clock. I have talked to a few other people whose clocks just stopped working. Evidentaly its a common problem, the local Ford dealership had it in stock.
mootang
907
texas
Mar 26, 2006
  • Mar 26, 2006
mine would go off when I turned on the headlights and then after a while of that it completely stoped working. I bought one on ebay for 10 bucks and now i have a working clock again. if you take the clock out and take it apart you will probably be able to see where it shorted. it lookes like a little burn mark.
will_95gt
298
Austin, TX
Mar 26, 2006
  • Mar 26, 2006
I took out the clock and opened it up. There is a burnish looking spot but its fairly rectangulaar which makes me think it might just be a brownish part of the clocks mobo because its geometric shape doesn't look sloppy enough to be a short.
I don't want to buy a new clock unless its deffinitely the probelm. I don't have another mustang to plug it into to test it so what other ways do u think i could diagnose the problem?
thanks guys, great info so far
95cobraguy
637
11
Concord, NC by way of LI, NY
Mar 26, 2006
  • Mar 26, 2006
i have the clock out of my car if u need it.
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
Mar 26, 2006
#10
  • Mar 26, 2006
  • #10
I dont know what the connections look like but you couldnt just touch the wires on the battery?
MysteryMachine
1,835
Parkesburg, PA
Mar 26, 2006
#11
  • Mar 26, 2006
  • #11
thats what i was thinking just hook it direct and see what hppens
A
Aggie 08
30
on campus at A&M Galveston
Mar 27, 2006
#12
  • Mar 27, 2006
  • #12
Hey does anybody know what wires go where and do what from the clock? A friend of mine has a mustang dash clock that he is trying to wire into his Ranger and he tried hooking power and ground up but it didnt work.. btw we plugged the clock into my dash clock harness and it works, so the clock isnt at fault.. Thanks
Wire colors: black, brown, white/purple, green, green/purple
donjohn
1,757
Mar 27, 2006
#13
  • Mar 27, 2006
  • #13
if you want to check the clock out, get a test light and check which wire on the harness is the power (12V) and black is ground (usually always) so you could get a 12V DC adapter and try it in your house
There may be a problem with doing this however, I'm not sure if the clock has a backlight, or when the headlights are on, it triggers a relay within the clock or something (trigger most likely happens). so I would think it'd be green for 12V and black for 0V
D
DJiCE
117
Bloomfield, NJ
Mar 27, 2006
#14
  • Mar 27, 2006
  • #14
Dude Replace the clock with a new unit..
Trust me it's the clock..
Mine had a large brown spot on the lcd and I replace it with a new one and works fine.
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
D
Progress Thread Today in the shed........
  • Don7Up
  • May 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 16, 2026
LILCBRA
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
