Clogged Cat?
  • Thread starter Thread starter SMOKEDYA
  • Start date Start date Jun 20, 2009
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Jun 20, 2009
  • Jun 20, 2009
If your cat is clogged will your car run like it has no power,and will it pass emissions still?I ask this cause it seems like sometimes my car is sorta peppy (for what it is) and also sometimes while driving it it seems peppy but then it can change to gutless all of a sudden. BUT it still passes emisions with flying colors.peace
john
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 20, 2009
  • Jun 20, 2009
A clogged catalytic converter would cause problems all the time, not intermittently.
Dumping The computer diagnostic codes on 86-95 Mustangs
Revised 19-May-2009 to update drawing for dumping the codes on 86-88 Mustangs with no check engine light.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
I
98 Mustang GT dying
  • ItsMason
  • May 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 25, 2026
lenzgt
L
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
Engine Surging idle on start-up
  • keel
  • Aug 11, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
keel
