cluch install
94_5.0
337
Jacksonville, NC
I just installed my SPEC stage 2 Clutch and It took all day.....How ever I was driving it home and it still feels like it is slipping...is this normal or is there something wrong? Pleas any help here would be great.
Did you replace or resurface the flywheel when you did the clutch? If you didn't, then that would be the first likely cause.
Did you replace the rear main seal? I it leaking at all?
Scott
Scott
Scott's ideas were what came to my mind too. also, you sure you dialed in the clutch adjustment correctly? if the cable is preloaded too much, it can slip. do you smell burning clutch material?
good luck.
I had the flywheel reserfaced and replaced everything. I do not know about the dialing in the cluctch adj ...uhmmm no I have no idea how to even do that. But when I push the clutch pedal in it is hard at first and then it goes really easy. I did not smell any burning clutch matereal. And the rear seal is good it was not leaking. So I am at a loss on this one
Can the preasure plate be put in backwards?
