clunk in the night?
According to my tuners, they all have a little play in the drive-lne. Mine does it also letting off and getting on the throttle at times. Mine is in the rear, it has a little play.
it could be bushings or a broken pinion ring tooth, could be to much backlash, broken sway bar, or you could be dragging somebody or something:D Are you missing any animals?:D
jack car up so the rearend suspenion and all is hanging then try moving the rearend side to side also check bushings, check gas tank make sure its secure.
Is it a constant clunk every so often or does it happen once per downshift/upshift?
