  • SN95 4.6L Mustang Tech
Clunk!
  • Thread starter Thread starter 68stang351
  • Start date Start date Jun 9, 2007
68stang351
850
9
39
Savoy TX
Jun 9, 2007
  • Jun 9, 2007
Sometimes in my 04 GT I get a "clunk" from the front suspension. It only happens when I'm braking and turning in somewhere, and that usually happens to be on uneven surfaces (bumps and what not).
I was up under my car yesterday, and all the suspension/steering components seem to be tight. I can't find any slack/unnecessary movement anywhere. I've investigated the tie rod ends, ball joints, etc. and can't figure out where this is coming from. Does anyone have an idea what could cause this?
It's my 04 GT w/ 40k, drives and handles great other than that.
lvmustanggt
721
Las Vegas
Jun 10, 2007
  • Jun 10, 2007
I have been getting same clunk few days now and I was wondering if it's my slotted and drilled roters cause it happen only when I back up and turn
EPIK
796
LEFT COAST
Jun 10, 2007
  • Jun 10, 2007
Check the front control arm bushings.
9
97 Stang
34
  • Jun 10, 2007
clunk
I have a '97 and I had a clunk on mine when i would brake, or when I would be in reverse then move forward. I put it on a lift and noticed that a brace under the car had come loose over time. The brace is just one rod that goes from the drivers side to the passenger side. There is only one bolt on each side. Both the bolts had come loose about 1 to 2 turns. I tightened those up and I haven't heard the clunk again.
TweekedGT
1,274
Alberta
Jun 10, 2007
  • Jun 10, 2007
Do you mean your front sway bar?
DTNODYA
831
  • Jun 10, 2007
Steering rack bushings...
EPIK
796
LEFT COAST
Jun 10, 2007
  • Jun 10, 2007
I think he's referring to the k member brace
lvmustanggt
721
Las Vegas
Jun 10, 2007
  • Jun 10, 2007
today I lift my front end and check everything every bolt , every things look to be ok . I rotate tire and no clunk. Don't know where it's comming from
9
97 Stang
34
  • Jun 10, 2007
No it's not either one of those. If I can get it on a lift sometime soon I'll take a picture and show you what I'm talking about. I'll try to get it up tomorrow at work.
68stang351
850
9
39
Savoy TX
Jun 10, 2007
#10
  • Jun 10, 2007
  • #10
I know exactly what you're talking about, I noticed the brace when I changed my oil. I'll check that, thanks.
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Jun 10, 2007
#11
  • Jun 10, 2007
  • #11
My '03's been doing the same clunk lately. I hate it
D
Disturbed One
191
#12
  • Jun 11, 2007
  • #12
I have a 97GT myself and I've had that clunking/knocking noise when ever I turn the car so far either direction or end up pulling into somewhere where the ground is uneven. It gets annoying and I've never been able to find it. Everything is tight, I've checked and rechecked and nothing. I've honestly thought it was in the transmission, 5 speed, cause that's about the only thing I have that makes any type of noise.
The little bar they speak of is right on or just behind the K-member and it's about 18" long roughly... been a while since I was under there.
96GTstang46
142
Seattle, Washington
Jun 11, 2007
#13
  • Jun 11, 2007
  • #13
You can always do the quick easy fix... Turn up your radio really loud!
HAHA jk, also if your car is lowered then did you put the rubber isolators back? cuz i know i didnt and my car clunked hella bad, for a while till i got some new ones.. Or you could just use bike tire.. someone said that works 2 lol...
lvmustanggt
721
Las Vegas
Jun 11, 2007
#14
  • Jun 11, 2007
  • #14
My car is lowered but I do have rubber isolators.
showstopper2
425
New Bedford, Ma.
Jun 11, 2007
#15
  • Jun 11, 2007
  • #15
my car used to make a clunk on startup like the exhaust was hitting the passenger side floor. since Ive done the longtubes I haven't heard it at all. front suspension makes all kind of noises in these cars once you get some miles on them. gives your car some personality!!
EPIK
796
LEFT COAST
Jun 11, 2007
#16
  • Jun 11, 2007
  • #16
Mine clunks all the time, but I got used to it....Especially after the Magnaflow catback & MM panhard bar...
D
darkside03gt
851
Sacramento CA
Jun 11, 2007
#17
  • Jun 11, 2007
  • #17
I had a similar noise for about 2 months i was first told it was my struts so i replaced them with tokico illuminas with matching springs and it was still clunking. then i was told it was the stearing rack bushings NOPE. finally i took it to the stealership and the found that my k menber brace strearing rack attatchment hdwr and 2 k member bolts were loose. try those before you start replacing anything look up the torque specs and hit all the suspenion nuts and bolts with a torque wrench
C
Noisy LCA
  • crazyone64
  • Aug 1, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 2, 2025
manicmechanic007
J
Severe shaking/vibrations in steering wheel
  • jacket999
  • May 20, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jun 1, 2025
NtheGAME
N
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
For Sale 3-owner 1987 Mustang GT, $18K obro, Lancaster CA
  • Bill Cool
  • Oct 6, 2024
2K
Fox Body Mustangs For Sale (1979-93) Oct 13, 2024
nickyb
