- Feb 13, 2006
- 97
- 0
- 0
i am swapping a 140Mph speed cluster from a 1990 GT into my 88 GT. I have the wiring harness from the vehicle i took the cluster out of and noticed it's different from the one in my car. Some wires are similar and others are different. Does anyone know where i can get the wiring schematic for both years? It should be possible to find which wires need to be moved and switch them correct?
any opinions on what i should do?
THE FOLLOW WORKS
- Oil pressure
- Voltage
- Tachometer
- Speedo
- Parking Brake light
THE FOLLOW DOSN'T WORK
- Water Temp
- Fuel Gauge
- Blinkers and high beam indicator.
any opinions on what i should do? THE FOLLOW WORKS
- Oil pressure
- Voltage
- Tachometer
- Speedo
- Water Temp
- Fuel Gauge
do you have a link to the webpage that can help me with switching the wires?
