Clutch Cable Fixed, However....
865.0
24
Hey Gang,
Thanks for all the advice.
I ended up purchasing a new quadrant, cable, and adjuster from Maximum Motorsports.
Wow!..What a difference. Light years ahead of my BBK quardrant and aftermarket adjustable cable. Sorry Steeda, as I have mentioned that I was using your products, when in fact, it was a BBK unit. That's what happens over a seven year lapse.
Anyhow, clutch pedal effort has been reduced dramatically, but now have a rattling sound when I engage the clutch.
Any suggestions.
Thanks in advance
if it does it after you let up off the clutch pedal it's probably the throw out bearing. you may need to tighten that fwa another turn or so to put some light pre load on the bearing to kep it from rattling....
HISSIN50, I will give it a look over.
What kind of problems should I expect with a bad TOB?
The car shifts nicely, it's just that little rattle when I depress the clutch. The Maximum tech guys told me to make sure I had the clutch adjusted properly. I gave it another go around this evening, and I can't get no better. If I loosen it, it grabs at the floor, and I don't want to over tighten it (FWA).
VIKING...All I can say is that the MMS combo is great. I have noticed that my cable alignment was off with the BBK unit, causing excessive wear on the cable at the bottom of the quadrant. I drove it like that for six years before the OEM cable let loose and another six months for the aftermarket adjustable cable. It may have been the alignment and not the quadrant, that was at fault. Giving BBK the Benefit of the Doubt.
Thanks for all the help
Yeah I first heard about the MM cable from HISSIN50 (thanks man) and I'll be installing mine this weekend... thank the gods!... I also have the same problem with the BBK alignment, when I put the second BBK cable in I noticed the cable had been rubbing the inside of the FW aduster. So I looked inside the hole in the firewall and sure enough the top of the quadrant is above the top of the hole, so the bending is what I imagined caused the cable to break. Bottom line, I aint buying anymore BBK stuff! Which is unfortunate because I've got other stuff from them that works perfectly... but I dont buy stuff from companies (anymore) that dont make quality products ALL the time.
The TOB can eventually come apart or seize. When they are (or arent - they are an issue like RMS's) properly adjusted via the cable, they can prematurely wear. WHen a load is placed on them, they make noise (which can be different from the noise they make when there is slack in the cable, as they are wobbling around on the TOB loose during that dynamic).
A chewed bearing retainer can allow what was a good TOB to make some noise - that was why I said what I did. One or the other of the two is likely (obviously should you find occasion to be in that far, renewing each for their relative little cost, is wise. Use a Steel retainer rather than aluminum).
Good luck.
Irrational said:
I just did my clutch and adj cable. I hear what seems to be the throw out bearing when the cable is slack (pedal not deppressed). Really sucks I am guessing it is my retainer. I hate this :bs:
A cable operated clutch should have some slight cable-preload at all times. If you dont have preload and hear noise, it might not be the fault of the TOB or bearing retainer, but simply the noise of the TOB being allowed to slop around on the retainer.
Good luck.
