clutch cable issue
  • Thread starter Thread starter 86turbo
  • Start date Start date Jun 5, 2009
86turbo
183
Jun 5, 2009
  • Jun 5, 2009
hey guys. Just installed my new t5 with a king cobra clutch kit, brand new tob and pilot shaft bearing. I have a upr firewall adjuster, triple hook quadrant and cable is fine. Here's the deal:
The transmission feels solid and the pedal feels great but sometimes I will get binding at the bottom of the pedal travel. I adjusted my fwa as per instructions with mmff having only minor tension on cable. Also, is there a way to get the pedal to engage closer to the floor?? If I just loosen up on the fwa then there will be play in the cable and thats bad
thanks,
Drew
FOOT2DFLOOR
108
Williamston, South Carolina
Jun 5, 2009
  • Jun 5, 2009
As far as the binding goes, idk maybe the cable is rubbing on your quadrent (not falling in the grove all the way). but if you have an djustable cable then just back out on the bolt at the clutch fork till you get your desired pedal position.
nisreo
178
  • Jun 5, 2009
what look on the triple hook do you have it on? should be in the middle.
86turbo
183
Jun 5, 2009
  • Jun 5, 2009
It is on the middle hook. If I loosen my cable up then there will be actual play in the cable and I don't feel right about that. I have heard mention of shimming out the pivot ball
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
2003 gt, clutch pedal stiffness.
  • 2003 mustang gt modded
  • Feb 15, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 17, 2026
Drivetrain Time to pull and lube the clutch cable
  • LX Dave
  • Dec 21, 2024
2K
Fox 5.0 Mustang Tech Jan 7, 2025
limp
Drivetrain Clutch cable?
  • flashback87
  • Jul 14, 2024
  • 2 3
4K
Fox 5.0 Mustang Tech Sep 29, 2024
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
