Clutch cable or quadrant?
  • Thread starter Thread starter MikeUrban
  • Start date Start date Dec 27, 2010
MikeUrban
187
Chantilly, VA
Dec 27, 2010
  • Dec 27, 2010
Hey, I have another problem... again. The car is a stock 93 5.0.
So, today I was on my way to a meet and everything felt normal. But I got to a red light and all of the sudden the clutch feels like jello, and it wont go into gear unless I hammer fist it. And once it's in gear with the clutch floored, if I let go of the brake it rolls like an automatic. I limp it to a parking lot and turn it off. I let it sit for a while and get in with the car off and it goes through the gears fine, so I turned it on and the clutch felt good and it went into all gears perfectly except reverse. A few seconds later the pedal starts to feel loose again and it wont go into gear. It also is really hard to get into neutral. What else could it be?
Thanks
W
white93LE
Jerzey
Dec 28, 2010
  • Dec 28, 2010
Check your cable for signs of fraying. I had one that was kind of doing the same thing, turns out the cable was starting to break, and had 1 strand of wire left. I bought the Steeda kit with wire, quadrant, and fire-wall adjuster. Once you get it adjusted it is great. But may take a couple of days to find whats right for you in adjustments
MikeUrban
187
Chantilly, VA
Dec 28, 2010
  • Dec 28, 2010
AWESOME! I'll go ahead and get the steeda kit. Thanks man!
HISSIN50
34
129
Dec 28, 2010
  • Dec 28, 2010
Agreed about the cable. The choice as to what kit to use is yours.
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Dec 28, 2010
  • Dec 28, 2010
go with the MM kit. Ive been thru my fair share of Steeda cables. MM uses an OEM cable that last longer and stays consistent longer. Use the search feature, this has been brought up here a few times.
MikeUrban
187
Chantilly, VA
Dec 28, 2010
  • Dec 28, 2010
I searched for it but they all had different symptoms than me, and I haven't learned much about clutches yet so I though I better ask. Thanks!
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Drivetrain Sticky clutch pedal
  • keel
  • Jul 31, 2025
Fox 5.0 Mustang Tech Oct 17, 2025
Mindseye007
