  • SN95 4.6L Mustang Tech
clutch cable problems
  • Thread starter Thread starter SHOWTIME!!
  • Start date Start date Jul 7, 2008
SHOWTIME!!
15
  • Jul 7, 2008
I recently put a new clutch and firewall in my 99 GT. I put a centerforce dual friction clutch and fidanza billet aluminum flywheel. I also bought a BBK clutch cable, quadrant, and firewall adjuster. I put everything in and it seemed fine, but the 2nd day i was driving it the cable got really stiff and it stretched then it broke. I called the company and they over nighted me another cable and they told me this was there HD cable, the same thing happened to this cable. We have looked to see if anything is binding up and we can't find anything. We put a HD clutch cable off of a fox body off of it today, it has stretched 2 times today but hasnt broke. Any suggestions will be helpful!
sveltre
  • Jul 7, 2008
hey i was having the same problem with my 96 GT. I put in a new clutch, flywheel and rebuilt gear box. i went through three cables in a few months time. i ended up down grading the clutch and changing the cable again but i don't know if you really need to do that. I ended up reading this on ram clutches web page
"I have a late model Mustang with the cable linkage, and the pedal is extremely stiff, or I have a problem breaking the outer casings of the cable."
"These problems can occur when the clutch quadrant is not positioned properly on the shaft under the dash. There are no 'stops' on this shaft, and if the quadrant does not line up with the cable routing hole in the firewall, the cable pulls at an angle and can cause heavy pedal effort or in extreme cases, breakage of the cable and/or cable housing. Be sure to sight the position of the quadrant when installing so it lines up with the cable routing hole."
Anyway i hope that helps. mine has been good since the new clutch and cable alignment.
BobHyatt
378
  • Jul 7, 2008
Check the cable installation carefully. Make sure the new quadrant is sitting properly on the clutch pedal shaft as well. The cable should follow the quadrant so that it does not get a sharp bend where the cable exits the housing. Sounds like something is wrong with how the cable is installed as these work fine normally, even on very stout pressure plates...
2000fordstanggt
404
Westland, MI
Jul 7, 2008
  • Jul 7, 2008
make sure the cable is routed *through* the motor mount
twogts4us
4,188
12
79
Dunedin, FL
Jul 7, 2008
  • Jul 7, 2008
Great post, great advice - and welcome!
Is the cable breaking at this end...under the dash? sveltre is spot on if this is where your problem is...
SHOWTIME!!
15
  • Jul 8, 2008
the cable itself is not breaking, it's the cable housing up against the firewall. It just seems to be breaking the little plastic housing that goes around the cable.
sveltre
  • Jul 8, 2008
SHOWTIME!! that happened to me one of the times the cable broke. What brand heavy duty cable are you using? Do you have a fire wall adjuster?
When i had that problem the part on the cable that goes into the fire wall wasn't sitting in the adjuster properly, causing excess tension on the cable. When i replaced the cable i eliminated the adjuster and went back to the old fire wall set up and adjusted the cable from underneath the car at the transmission.
twogts4us
4,188
12
79
Dunedin, FL
Jul 8, 2008
  • Jul 8, 2008
Did you follow the instructions when installing the firewall adjuster? You have to remove parts of the cable to fit against the FW adjuster.
the end result should look something like this...
For additional help (and GREAT) pics, take a look at the instructions for the Maximum Motorsports FWA, item # MMCL-3 at http://www.maximummotorsports.com/i...rsports.com/store/index.php?main_page=install
SHOWTIME!!
15
  • Jul 8, 2008
It's a BBK cable and quadrant. We ended up just going back to the way you said. It seems like the cable it's self is sticking. If i have the clutch pedal to the floor and lift off of it enough to make it start engaging, then push the clutch back in to disengage it, it wont. It will just sit there trying to engage it's self and the car will just be shaking until i jerk it out of gear. Then i can fully let off the clutch and push it back in and everything will be fine. I dont know what to do at this point.
sveltre
#10
  • Jul 9, 2008
  • #10
i was having trouble with the bbk stuff as well, when i replaced it after the 2nd time i went with zoom its held up since. But i would try another brand if you are also having problems with bbk.
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Drivetrain Time to pull and lube the clutch cable
  • LX Dave
  • Dec 21, 2024
2K
Fox 5.0 Mustang Tech Jan 7, 2025
limp
