Clutch Cable
  • Thread starter Thread starter GATOR98GT
  • Start date Start date Jun 5, 2004
G
GATOR98GT
185
BRISTOL
Jun 5, 2004
  • Jun 5, 2004
Can anyone help me with an idea of how to install a new clutch cable? Does any one have any diagrams or anything? Also about how hard is it.
Yes I am very slow
Henceforward
The Avatar Master
485
  • Jun 5, 2004
I did this last week. Ok here it goes.
Jack up the car. Support it real good with proper jack stands.
Get under there and remove the dust shield on the bell housing.
Then pull back on the clutch fork really hard, at the same time remove the cable by moving the cable end towards the larger hole on the clutch fork end.
Push the cable through the line a little bit to make it easier to remove the cable from the quadrant.
Then crawl under the dash, and disconect the line.
After that, go to the firewall, and remove the sheetmetal screw holding the cable tab on the firewall.
Then carefully remove the clutch cable, don't just yank it out, take it easy.
This is further explained in greater detail in the haynes manual 36050.
Chapter 8 Clutch and Driveline. Specifically 8-6.
I can help you more in the morning. No pics right now.
G
GATOR98GT
185
BRISTOL
Jun 14, 2004
  • Jun 14, 2004
Did you get any pics yet? i am having a hard time removing the cable from the clutch pedal. I am to big, i took out the seat and tried to get under there and i still can't see anything. Any help would be greatly apprciated.
GToddyT5
553
Hamilton, NJ
Jun 17, 2004
  • Jun 17, 2004
The quadrant is to the right of the steering wheel if you are sittin in the driver's seat. It's on the end of the rod attached to the pedal. It's on the opposite side almost above the gas pedal.
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
