clutch cable
  • Thread starter Thread starter wildstang87
  • Start date Start date Jun 27, 2005
W
wildstang87
96
  • Jun 27, 2005
how long should it take me to change my clutch cable? any tricks??
bullitstang1313
713
Indianapolis / Columbus, Indiana
Jun 27, 2005
  • Jun 27, 2005
Are you using an aftermarket cable or stock? Is the clutch quadrant stock or aftermarket? Do you have a firewall adjuster? It should take very long to do, but it depends on your set-up. I would say about an hour at max.
blkstangman88
646
  • Jun 27, 2005
just the cable swap is fast but while ur at it u might as well install and new quaidrant and firwall adjuster, DONT GET A AFTERMARKET ADJUSTABLE CABLE! i cant stress this enough, i went through one in a week, get the oem one from ford with the firewall adjuster.
W
wildstang87
96
  • Jun 27, 2005
im just changing the cable, not the quadrant wich is stock, my cable is strectched and it wont engage the clutch all the way. will i have to reset the stock adjuster, or will it be self explanitory when i look at it??
89CopCoupe
Banned
Feb 17, 2004
606
Post Count City
Jun 27, 2005
  • Jun 27, 2005
The stock quadrant and "adjusting ratchet" is plastic ... but is self explanatory.
The easiest way to get at it is to remove the 4 bolts to take the drivers seat out so you can lay on your back inside the car and look under the dash.
Total time about 1/2 hour once on jack stands.
I suggest getting the triple hook quadrant, firewall adjuster and adjustable cable from these guys for about $60: www.uprproducts.com
Mine has worked great for over a year with minimal stretch ...
89white50
440
central MA
Jun 27, 2005
  • Jun 27, 2005
My cable snapped 2 weeks ago. I bought the high ramp 3 piece kit from jegs. short ass pedal travel, makes shifting fast a breeze. come with a new cable, friewall adj, and high ramp quadrant. Worst thing is getting the old **** out. much better now.
blkstangman88
646
  • Jun 27, 2005
dont get a adjustable cable, those are crap, the oem is much stronger and will last alot longer. like i said b4, mine snapped after a week and i got a king cobra clutch, which isnt that much better.
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Engine Standard or hi flow water pump?
  • AnthonyA1234
  • Sep 28, 2026
Fox 5.0 Mustang Tech Oct 9, 2026
2000xp8
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
