No sweat. Cable can be done in minutes once you know what you are doing - it takes about as much time to get it up and on stands as it does to swap cable. Routing the cable is the hardest part so note where yours runs before pulling it. There is one screw on the bracket attached to the cable and one on the dust-cover of the trans. No other tools required.
With the stock quadrant, hook the trans side first and then lift up on the clutch pedal and hook up the pedal side. Operate the clutch and it will self adjust.
With aftermarket, it does not matter which side you hook up first - use the firewall adjuster to take out most of the slack.
Just make sure to use a good cable. Some of the aftermarket ones out there are crap and stretch. A new Ford part is safe as well as some of the bigger aftermarket names.
