Clutch chatter advice please
  • Thread starter Thread starter Jon22
  • Start date Start date Apr 23, 2011
J
Jon22
25
Marietta, GA
Apr 23, 2011
  • Apr 23, 2011
Hello all,
I have posted/asked about this issue in the past but, at the time, I was sure that the problem was wheel hop and not clutch chatter. I am sure now that clutch chatter is the problem.
My setup is a 289 with T-5 trans, spacer plate adapter with 4speed bellhousing and, all of the stock z-bar linkage. If anyone has found a way to fix this problem, I would appreciate the input. I would like to keep the stock linkage if possible but, a cable or hydraulic setup is on my radar as well. I am just ready to be able to start from a dead stop on a hill without the whole car shaking violently! Any advice is appreciated.
Jon
zookeeper
3,415
63
109
Rogue River, Oregon
Apr 24, 2011
  • Apr 24, 2011
I'd check external things like the engine mounts (and the trans mount) first. A loose, broken or worn mount will cause chatter, as will weak rear springs. If that's not it, I'd start by pulling the trans, inspect for leaks and having the flywheel surfaced, then replacing the clutch and pressure plate. Not cheap or easy, but that's about all that can cause bad chatter.
PoppyMod
617
Severna Park, MD
Apr 24, 2011
  • Apr 24, 2011
+1 with Zookeeper.
Dont start throwing money at it like thinking ing of replacing "Z' linkage etc. All you need is a little oily mist to create chatter/slippage. If you pull it, replace the clutch with an organic/Kevlar or full Kevlar, as they (both) are resistant to the affects of oil.
Good Luck!
J
Jon22
25
Marietta, GA
Apr 28, 2011
  • Apr 28, 2011
Thanks for the advice you guys. After looking into things further in the past few days, I am thinking that the stock 65 motor mounts may be my problem. The drivers side mount is in pretty sad shape and the z-bar is at a loose down angle from the frame. I am going to start with new mounts and then make sure that the z-bar is strait and tight.
R
Randy'65
352
Richmond, VA
Apr 29, 2011
  • Apr 29, 2011
The tube portion of my z-bar actually started ripping at the flat bar weld, opening up just enough when I was on the clutch that it would cause some chatter. Got it re-welded and fixed the problem. Check and make sure that nothing looks weird in the entire stroke of the clutch linkage, have someone else press the pedal while you watch.
mustangmutt
339
El Paso, TX
Apr 30, 2011
  • Apr 30, 2011
Make sure all the Z bar and clutch release components are in good condition, including the pedal assembly. I recently rebuilt a pedal assembly with a roller bearing kit and it eliminated about 90% of the chatter on a 3 spd, which IMO are prone to chatter. Also, did you replace the pilot bearing when you did the T-5 swap?
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
Engine Head/Cam Recommendations
  • CWSpartan
  • May 29, 2024
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech May 31, 2024
Engine Bad engine shaking at idle
  • sav22rem22
  • Jan 2, 2024
6K
Fox 5.0 Mustang Tech Feb 2, 2024
sav22rem22
