Clutch Chatter
Suspect is the throw-out bearing. It is nearly impossible to put it in backwards without noticing. There are long and short throw-out bearings. If you put in a bearing that was shorter than the one intended for the clutch, you would have exactly the situation you described..
Clutch chatter started around 200 miles and is getting worse. Anyone else notice this condition?
The clutch chatter is normal, and I believe they even state that in the owners manual. I have pretty much figured out a way to drive it so it doesn't chatter anymore though. I think with some more gear it would be almost non existant.
