  • SN95 4.6L Mustang Tech
Clutch fork vibrating.
  • Thread starter Thread starter jahernandez
  • Start date Start date Nov 30, 2012
jahernandez
64
Tulsa Oklahoma
Nov 30, 2012
  • Nov 30, 2012
Clutch fork seems to be vibration pretty bad and making a noise. Car shacks very bad moving from a stop as I let the clutch up. Once the car is moving it drives perfectly fine. Anyone have any ideas on what this could be?
The car is a 2003 GT Mustang.
blacksheep-1
322
Nov 30, 2012
  • Nov 30, 2012
on some occasions the input shaft wobbles around so much that it occasionally whacks the case. This happens on many transmissions like the T5 and T45 that are abused. Basically the case elongates and creates more end play. Probably not your problem, but check the end play to be sure while you're there.
It might be the fork is worn out, the hub could be worn a couple of things can cause this.
BurningRubber
1,865
24
58
Dec 1, 2012
  • Dec 1, 2012
Sounds like an improper cable adjustment.
Are you running a stock, or replacement cable? Adjustable, non-adjustable? Is there any slack in the cable or your clutch pedal?
There needs to be some type of pre-load on the clutch fork, which will in turn keep the throwout bearing from bouncing on the face of the pressure plate and making the squeaking noises and cut back on the vibrations.
jahernandez
64
Tulsa Oklahoma
Dec 2, 2012
  • Dec 2, 2012
I'll lift it back up tmw and check for play. I also have another video to post.
It seems the vibrating on the clutch fork stops once the clutch is
pushed in and most of the noise goes away as well. Once it's in gear and driving
(Letting the clutch back up) it starts to shake again and the noise is back.
I'm running a heavy duty clutch in it. The cable should be stock unless
The previous owner had changed it and there is no play on the pedal at all.
The clutch I have in here also only has about 2000 miles on it but I've been having
this problem shortly after install around 400 miles.
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Dec 3, 2012
  • Dec 3, 2012
My vote is the cable is stretched. As they get older they will stretch a bit and cause the issues you are experiencing. While you may be inclined to get a new cable I'd get a fire wall adjuster and a quadrant if you still have the stock set-up. If it is stock, try lifting the clutch pedal toward you then pushing the pedal to the floor. The stock set has and auto adjust but if it is already adjusted to the limit it may not change anything.
jahernandez
64
Tulsa Oklahoma
Dec 3, 2012
  • Dec 3, 2012
My clutch pedal does shake but would a stretched clutch cable cause the car to vibrate on take offs? The vibration is somewhat if the car were going to stole but it isn't, kind of hard to explain.
As far as adjusting the engagement higher on the clutch pedal (I think that's what your asking) I've got all of that dialed in. Is there a way to tell if the cable has been stretched? Like getting under the car and pulling it a certain way.
jahernandez
64
Tulsa Oklahoma
Dec 5, 2012
  • Dec 5, 2012
Here is another video of the problem. In this video I show myself pushing in the clutch which stops the sound and the clutch fork from vibrating.
02MustangGT46
9
  • Jul 16, 2015
Figure this out yet? Same issue. My pedal vibrates also, does yours?
02MustangGT46
9
  • Jul 16, 2015
Everything between the engine and the transmission itself is brand new for me also..
Savagemach1
#10
  • Mar 18, 2018
  • #10
I know this is an old thread, but having same issue... did you ever figure out issue?
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Saturday at 12:05 PM
fasterthangas
F
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Sep 13, 2026
Mcmahst
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
1998 Mustang Gt Rattling sound, cannot locate. Video included
  • studerman1
  • Mar 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 1, 2026
studerman1
