Clutch going bad causes...?
GitDat
529
Indy
I noticed my clutch started slipping a couple of weeks ago. Then I started noticing after shifting and releasing the clutch that the shifter would pop out of gear more often. Last night I was at a light and pressed the clutch to the floor and tried to shift into 1st and it would not budge until I released the clutch and pressed it back down again. Are these all signs of a dying clutch or do I possibly have another issue going on as well? :shrug:
im not good with clutches,but you might should check the fluid..i should know by now,but still dont know.. ive put two in mine about to be three and i dont ride the clutch, i just bought a cheap one form advanced and wont do it again..if you do have to buy one definately spend the money and get a better one
fluid level
check on the passenger side of trannys there is a plug in the side that is a 3/8 ratch will open and fluid should be up to the hole now there is two its the top one dont remove the lower one buts I agree with hotrodnut the syncos are bad.
